k& n air filters
Enigma
righto chaps, here is all the info you need :)
the first pic of the original airbox has an element 142x90x65mm.
the closest k&n is 136x89x65mm which is perfect as they can be smaller o/d anyway [8D]
part no. E2330.
next pic is what sybhil has fitted the duct is standard (2 in pic for clarity) with a clamp on type filter, this one is rated at 85 bhp airflow, so its ok for commers [^] except will & daves :D;)
part no. RU-1820
available with chrome or rubber end.
the main supplier is
K&N FILTERS (EUROPE)LTD
JOHN STREET
WARRINGTON
CHESHIRE
TEL. 01925 636950
PHEW [|)]
Or here Scott....don't you ever pay attention???:D
Dodgemark
cheers tim;) dont know which one do you, and does it fit under the pass seat where the bath sits[?] dont suppose you do silencers do you tim:p[?]
commeracer
No idea :I but they are listed by size, so just measure up where you want to clamp it and get the biggest one that will fit in the available space. They have a 2-3mm tolerance on the clamping size so it,s not critical :)
Silencer wise, just get an RC40 from Epay or Mini spares centre ;)
Enigma
will fitting an RC40 to a diesel still increase the horses then Tim??
Enigma
plenty of room for it Mark, it's not like your van has a water tank in the way lol
commeracer
What diameter is the exhaust pipe Mark [?]
Dodgemark
hi tim 1 1/2" mate;)
commeracer
Then there is no reason you can,t use an RC40. Diesels are easier to silence :)
Dodgemark
dont really want to go to that expense now:I as i have a new tail and downpipe:) its just the silencer i am having trouble getting hold off:(
MandnMark
right i get the kn filter but what about the rc 40 exhaust is that not for a mini ? if so how easy is it to fit im assuming there is some feteling involved ?and considering every time i do one job on homer i make three more this could be a worry
Mand N Mark
Tims step by step guide[8D]
http://66.129.69.181/forum/topic.asp?TOPIC_ID=6798&SearchTerms=rc40
Two's company
Navyreg1970
part no. E2330.
part no. RU-1820
JOHN STREET
WARRINGTON
CHESHIRE
TEL. 01925 636950
PHEW [|)]
hr height=
my new business
Yours being an oil burner and all - wouldn't it be different:I
How refreshing
Navyreg1970
I think it can take a K&N, Its just what do I connect it to as I have nothing there at the moment
The Dog is home....
my new business
A measurement of the inlet on your engine would be useful, then we could compare it with the carb inlet and see if the inlet bend would fit.
How refreshing
Navyreg1970
will get the measuring stick out in the morning - getting the injectors out tomorrow to see if they need a refurb. 20 watt flexible solar panel is on its way to permanently mount just behind the bulge of the Luton bit - Have ordered a solar split charger that sends 80% to the start battery and 20% to the leisure battery until it senses the start battery is full, then it switches to 100% into the leisure.
oops sorry wrong thread, forgot, this is K&N
The Dog is home....
my new business
