Installing a car stereo.
If you can...take a pic of the cables coming from one of the speakers and mail it to me... and yes you are confusing me...what is ''acing lighter''
LOL you and me both!:)........so we just got to wait now until you can borrow your mates tester;)
Hi Colin the green wire has got a positive feed but we didn't check the blue wire but I think we got a positive feed off that as well when he checked it earlier. I can't find an earth on the commer. With the blue wire does the ignition need to be on?
Andrew, I need you to test the blue wire with the ignition turned on and again with the ignition turned off
then I need you to test the green wire with the ignition switched on and again with the ignition switched off
Then I need you to tell me all 4 results please:)
ok, so now I know about the blue one......thanks
now i just need to know the results for the green one.....
and also a picture to my email of the speaker cables at the back of one of the speakers, and then we are nearly there mate...
Hi Colin I wil do that tomorrow when I see my mate again, Is there going to be just an earth coming from my stereo? And no earth coming from the commer.
Yes, thats right ...I don't want to tell you too much in one go as I don't want you to get confused mate, so we will just focus on one step at a time , hope thats ok with you...
Andrew if you want a
When you have finished installing your radio
Please get someone to check your wiring before you turn it on or you might end up with
Gladys & Bernie
How would it need to be wired to make it go boom.? Is as simple as switched live to switched live permanent live to permanent live speakers to speakers earth to body and ariel to back of radio? I am also going to put a fuse box in between commer to CD player.
Bernie is joking about a 'boom' box also known as an amplifier and subwoofer ....mate trust me, your head unit is probably not compatible and you would defo need an expert to fit it for you....plus you are talking loads of money.....I have installed this kind of system in my car.
No I don't want a amplifier or a subwoofer I thought it would really go boom:) I just want a standard CD player so I cn listen to Roy harper and the levellers.:D
Ok, Andrew, I will try and make this a slow, step by step guide that you can understand and remember you can look back at some of the pics I have posted to help you....
First of all I want you to plug your ISO cable (adapter lead) into you cd player and then I want you to cut/remove the plug on the other end...see pic..red arrow into cd player and cut the plug off where the yellow line is...
Ok, next you need to disconnect your battery from the van....disconnect the + positive side first...
You now need to join the blue wire in the van to the red wire on the ISO (adapter)
Join the green wire on the van to the yellow wire on the ISO (adapter)
I advise you fit a 10amp inline fuse to both of the above:)
The black wire coming from the ISO (adapter) should be attached to the van body...if you crimp a loop( see my previous pic) onto the black wire and drill a small hole in the van (plenty near where you are installing your cd) scrape a little paint away and secure with either a small bolt or a self tapping screw..
You may find you need to extend some of the cables, I think/hope by now you will feel confident enough to be able to do this.....
All you have left to do now is the speakers and the ariel ....the ariel should be obvious...
Ok, speakers..
From the ISO (adapter) you should have a white wire, connect this to the + left speaker
from the ISO there is a white wire with a black line/stripe, connect this to the - left speaker
from the ISO you should have a grey wire, connect this to + right speaker
from the ISO you should have a grey wire with a black line/stripe, connect to - left speaker.
That should be it...any other wires from the ISO, fold the end over and wrap them individually in insulating tape then maybe just hold them together with a cable tie to keep things tidy...
When you actually fit the head unit to the van, make sure it is fitted securely and doesn't jump about/move when you drive along or go over bumps in the road etc...
That should be it, job done......;)
