I wasn't sure, when I put these pictures on, if they would be of interest but as eveyone usually says "the more pictures the better"
and it also shows what a great job Woolfy's doing of making Lulu the prettiest commer around.[8)][8)][^]
This is obviously the door with the handle and lock on the outside but I can't remember how the other door fastened shut, does it have bolts on it and also while I'm on about it, I once asked , on here if there was anyway to lock the door from the inside when you're sleeping in it and the answer was to drill a hole and put a bolt into the hole. I am hoping someone can show me a picture of the inside of their door with the bolt in it or make a marker on this picture. Cheers and beers
This is the left hand door, it has catches top and bottom attached to the rods you can see - it's the right hand door that has the outside handle on and a central catch that clicks into the bit you can see to the left of the handle in the picture.
I used to lock it with the key from outside and latch the other one shut. Then when we were ready for bed time i would give the curtain wire a tug and the weight of the door was sufficient to close the door and it would already be locked from the outside. The latch needs to be well lubricated.Or you could attach another handle.
The fuel pipe cover on mine appears to be made of fiberglass, should be easy to reproduce, maybe a new product line Martin.
Rain, hail or shine a Commer adventure awaits,,
Mount up!.
www.commervanoztour.blogspot.com
Thanks to Paul and John for the information about locking the back doors. I seem to think that there was an article about drilling a hole and putting a bolt or a bar through the hole.[)]
It's strange because the Readers Rides page says 18 pages but if I click on 18 it says page 1 of 17 but if I try all the other pages from 1 to 17 they all show correct so really it's a phantom page.
Originally posted by commerchris
Page one does not exist my end....I get 17
pages
