Enigma
0
you musn't see it as failure Ray...merely a learning process
like i think panky suggested, run a switched live straight to the solonoid and road test it (can't say enough though...only as a temp measure to see if it all works and ONLY switch on when in 3rd or 4th and make sure you switch it off during actual gear change from 3rd to 4th) at least then you will know if its either the wiring or inhibitor..
i will get out in the morning and take photos of my wiring and relay...i didn't bother before as panky posted the diagram
