Fuel problems
Hi Guys, I am after some technical advice. My van has been laid up for a few months, and upon starting it it will not start. Got the AA out who are not sure, but know the problem is:
The carb is flooding and peein out fuel into the manifold. The carb was stripped so far and nothing found. AA reckon its either a problem internal with the carb or too much pressure in the fuel pump. Any Ideas?????
The carb is less than a year old and is a weber.
Im camperless until its fixed:(
Super Super Cool
If its dribbling then its a gasket probably. If its peeing out then reckon the AA is right
Dont know what the aa did or I did when he told me the problem, but I played about with it, and starting and sounding as sweet as a nut. Guess I need to use supercoolcommer more.....
Thanks for your input Gav.
Super Super Cool
It could have been the float sticking and the chamber overflowed. You need a tap on the side of the carb......with a screw driver : )
Harvey the RV
Cheers Panky I will keep that in mind when I lay her up next time:D
Harvey the RV
Super Super Cool
