Fridge and bits
Hello all we have disposed of our caravan due to the sides parting company with the floor on the last holiday in September of this year, the van was in good nick upto this point and was regularly serviced and gas tested.We now have the following for sale that may be of use to you commer owners.
Electrolux fridge - 240volt, gas and 12volt. brown body and surrounds with a teak wood effect front door, gas tested earlier this year and in good working order when removed.complete with vents and flues.
Height 620mm Width 490mm Depth 500mm £60.
240volt RCD trip box with test trip and two circuit trips, good for fridge control and 240volt sockets and battery chargers, good working order. £10.
Strip lights x2 brown frames, push button switch.12volt good condition
Length 555mm Width 45mm Depth 25mm £5 each
Strip light x1 brown frame, push button switch.12volt good condition
Length 360mm Width 55mm Depth 25mm £5
Strip light x1 all white, pull cord switch.12volt good condition
Length 370mm Width 40mm Depth 40mm £5
If you buy all four lights i'll do them for £15
Nathan 07867 858170 all items 5 mins from jnt 9 of M5
Im all thats left of a bizaar childhood!
Hello I might be interested in the fridge if it would fit into the place where my autosleeper fridge used to be. Unfortunatly I can't get in the van at the moment (snow you know...) any ideas what size the cupboard is?
thanks
Rupert
"With great beards comes great responsibility"
www.littleyellowcar.co.uk
The height and width of the fridge is also the size needed of cupboard as the cupboard sides and top touch the fridge and the depth is the full depth needed to fit all the pipes and flues in at the back, hope that helps. sorry i have no idea what the cupboard size is as i have an unoriginal coachbuilt. Sorry i cant post pictures!
I started this life with nothing, i still have most of it!
I now also have a drop down sink complete with tap (hot and cold) and a vanity/medicine cabinet, both screw to the wall affairs and in a cherry terracotta coloured plastic.£10 the two.
I also have a drive away awning for a poptop van, its a metal frame and plastic canvas type and has had very little use. i think its made by adventurer and was very expensive new. £50 ovno
get photos if you can Nath,one of us can post them for you :)
if i hadn't picked up the retro tent I would be interested in the awning.
Sybhil & no1
Hello Chris thanks for that, it would really help. The problem is getting photos to you, i dont have a digital camera so i will have to take them on my phone then bluetooth them to computer then email so may take a while.:I
Hello Chris if i was to take the photos on my phone and text them to you would you be able to get them posted, and if so can i be cheeky and say can you do it for me please as i just dont have the time to get on our computer at home at the mo.[?][?]:p
