Hi all, sorry not been around much lately. Maybe get be a daft question...Thinking of fitting an electric water pump over winter along with and electric fan. Question is With the pump, after removing the fan would you just bypass the fan pully with a shorter fan belt and leave the old pump in there I.e would the water pressure from the electric pump just spin it anyhow and therefore not cause any problems? Removing the pump itself and blocking the resulting hole would be a right pain (also the heater feed goes directly back into the pump housing which would make it even more difficult). Also would you leave in the thermostat or remove it and allow the pump to regulate the flow?
