Dusting off the cobwebs
After winter in storge she started first turn of the key - well almost! Just had a quick run out and everything seems fine but is there anything I should be checking, changing or adjusting after a few months of hibernation?
My father in law gave me a dehumidifier which I ran in the van before it's first outing last Weekend to Creiff. In the space of a week it extracted 12 litres of water from it! I was staggered, but the van was almost completely condensation free when we woke up on the Sunday morning, usually at this time of year the windows are running with drips.
I would therefore highly reccomend putting one into your van/s before the season starts.
Ruairidh
I have used refillable tray type ones they last about 3 mths,just empty at least once a week,gimp uses a tin of salt in cloe,also used a small portable electric one,it is amazing how much dryer it is after using them...
Sybhil & no1
Cheers guys, the draws had expanded and jammed shut so this sound a idea - better than mine anyway which was to drive round with the windows open!
Get the ramps and grease gun out get pumping :D Adjust the brakes and check seals etc for weeps and leaks - not forgetting to look around for any tell tail signs of corrosion, the sooner you treat it the less likely it will give you a problem in the future.
Crikey did I just say that lot - a bit sensible for me :I
