Dora
Also a common problem is the gear linkage bushes x2. Martin sells them cheap, simple job skill wise but a real pain to put in the front one. Don't do it in the cold cause you get a few rapped knuckles :). They're riveted in before you start so worth having a gun ready if you do change them.
Hasta la supervista baby
That's in case you should see the bloke who designed them, then you can shoot him [}:)]
had a prod about today not good news i'm afraid [V]
will take me a lot longer to get the money to pay and get this sorted properly ,
fibre glass and filler...[}:)]
needs major work on the front panel alone, inner sills are shot too, went on to
the forum to see if any panels were for sale as I need "all" the lower outer panels and door sills .going by the prices of available panels will not get change of a grand ,then labour[xx(]
but determind to get my dream sorted
found an old thread for the van
http://forum.commervanfan.co.uk/topic.asp?TOPIC_ID=1476&whichpage=1
didn't find the old auto sleeper badge inside , so looks quite an expensive job in toll which is not good news .
Also found I drove home with no front lights "thought the lights were not very strong" , a bit luck on my side ,found the lpg hose had rubbed all the braided coating off , as it was rubbing off the rocker cover , the chance I took without checking properly myself first.:I
on the plus side today got the radio to work by plugging in the ariel :)
Ouch!:( ......I'm not sure if it's for sale but I know Tim (Commeracer) has a spare front panel and his rates are reasonable...;)
Tim , are you taking on any extra work?
could do with a bit of stainless added to ours
:D:D:D there is a god.....thanks
as you can see he needs some tlc
[email protected]
cheers
Davie.
Yes, certainly :)
