Not necessarily. When you fit a new dizzy (have you taken out that broken bit yet?) you may find that the engine won't start properly or at all. If that's the case you may have to remove the dizzy then turn the engine 1 revolution and re-fit. IIRC no.1 cylinder reaches TDC twice during one revolution of the engine, if you re-fit the dizzy at the wrong one it won't work. Sometimes people just swap the HT leads round to correct this but I'm not sure which ones you swap!
Anyway, this is all academic until you get that piece out and make sure there is nothing else loose down there. Then fit another dizzy and see how it goes.
Peggy drinks too much!
