Hi, I'm after a dipstick for a later engine, goes next to the oil filter housing. I'm also after a couple of senders, I'm not sure what they are but they're the ones on the block in these 2 pictures.
1st, is the one at the bottom of the block, towards the flywheel.
2nd is the one in the center of the block, with 2 spade connectors on.
I assume the 2nd one is for water temperature? If so, I'm wondering if I can block it off because I've got one on the thermostat housing, and one on the radiator. I've no idea what the 1st one is for.
