Dipstick for later engine and a couple of sender?
Hi, I'm after a dipstick for a later engine, goes next to the oil filter housing. I'm also after a couple of senders, I'm not sure what they are but they're the ones on the block in these 2 pictures.
1st, is the one at the bottom of the block, towards the flywheel.
2nd is the one in the center of the block, with 2 spade connectors on.
I assume the 2nd one is for water temperature? If so, I'm wondering if I can block it off because I've got one on the thermostat housing, and one on the radiator. I've no idea what the 1st one is for.
The first one is the position for oil pressure switch, it looks like there's a connection for a pressure gauge screwed in at the moment but that will just undo. The second one I think you mean is actually a drain cock for the water jacket:)
The engine looks great but I don't think you will get it in with the Arrows water pump and fan - and you will need to fit the Commer front plate as it's got the engine mounting points on it:(
Ah-ah! Thanks for clearing that up. Sorry, I should have said that wasn't my engine, just one I found showing what I need.
This is my engine
