still to small for me I guess ,because my ford OHC 2.0 with automatic A4ld trans is doing 50 mph easy but the RPM's are around 4500 to 5000 > and that's causing problems with the cooling system
anyhow i'm changing to a ford MT75 manual transmission ...but that still doesn't solve the RPM issues !!
so I need a different diff that fits my commer axle somewhere in the 4.3:1 or 4.6:1 ish ........or when not available change the whole rear axle for an Atlas type ford axle
You could fit a Rover P5 or P5B axle, the P5B has a diff ratio of 3.54 and is the same stud pattern as a Commer. The P5 ratio is 3.9 and they are interchangeable with Land Rover (4.7) and RoverP4 (4.3)
