hi peeps, thought i would ask the advise if anyone knows, Sorry this is about my cortina and not a commer.
My rear diff has been leaking from the oil seal, so i have bought a new one and before thinking about anything i removed the prop and prop to diff flange removing the pinion flange nut.
I found out afterwards that the diffs are pre loaded, i found out the the pre load setting is between 12lb and 18lb.
Now i think i have this right, I have removed diff, replaced the crush sleeve, put diff back onto the axle, inserted new oil seal and attached prop/diff hub and lightly screwed the pinion nut.
I take it what i have to do is slowly tighten the pinion nut stopping each time and measuring the force it takes to turn the hub round using a spring weight through one of the prop bolt holes until this reaches between 12 and 18lb ( Ideally 15lb as a middle figure ).
Has anyone done this before on a commer or anything else to tell me if i am doing it right and i think i should also have the wheels removed so as not to create a false resistanse.
Cheers for any help
Cheers for any help
