PaulJL
0
The van needed a towbar. It didn`t have to be anything fancy. I tried taking one off a van in Martin`s yard but it wasn`t gonna budge. A friend of mine told me he had a detachable bar that was nearly new and I could have it...... I used it because it was given to me to use, Being a Yorkshireman means I had to use it. lol.
It`s a westfalia detachable neck bar from a BMW 3 series saloon E36 shape.
2 plates were cut from 6mm thick steel and bolted to the chassis. The distance between was the bar length. The bar has curves in both directions so a cunning plan was concieved. Using a spirit level and set square the ends were marked and cut off.
the remaining webs were cut off and cleaned up.
The whole lot was mocked up under the van and after draining the fuel tank the bar was tacked to the plates and removed..
This was all then seam welded using an industrial MiG, rubbed down and painted.
When the paint dried it was just a case of bolting to the chassis with 12mm bolts and sleeves to stop chassis being crushed.
This has gotta be a first? Detachable tow bar on a Commer/Dodge???
1. Stuff I`m keeping
