Originally posted by Navyreg1970
throttle dropping back too far?
not sure on the petrols, but the diesel has an idle setting screw as well as an anti stall screw that will overide the idle setting if required
or maybe its one of those new fangled commers with stop start technology.
it will help if you let us know what engine / carb combination you have - and does your fuel line run near anything hot?
The Dog is home....
my new business
I'm with Lee on this one, happened to Babs a few times, I found the throttle idle screw on the side of the carb had unwound itself a little bit, always seemed to happen exactly as you describe it, seemed to tick over ok but a drop in revs after running usually resulted in the engine cutting out. The two lights are warning lights for oil pressure and ignition live. They only come on because 1. the engine has stopped and as such the oil prssure drops and 2. the ignitions still on.
try turning the screw up, (clockwise will increase engine idle speed). So with the engine idling, stop turning when the idle speed increases, only small ammounts though, no more than 1/4 turn then wait and listen. It'll sound right if that makes sense...
