Originally posted by Jon
Originally posted by TV8
The way the split charger is wired on Debs (Moley) van "Brian" is as follows, once the main battery is charged up to 13.2V the split charger switches in and puts a 12V supply onto the fridge and also 12v on to the leisure battery from the alternator. Whilst the main battery maintains 13.2V the split charger stays switched on allowing the alternator to supply the fridge and charge the leisure battery. The coil is fed via a fuse and the ignition switch off the output from the alternator and what seems to happen on Brian is when the ignition is switched off to kill the engine the voltage spikes which is what I think blew the Sat Nav.
Deb also says that with the alternator feeding the split load, fridge and leisure battery Brians power was really down making hills more difficult than usual which points to the alternator struggling to supply the load caused by the leisure battery and the fridge along with providing power to the coil circuit which may be why the coils burnt out, less volts = more current to satisy the same load, more current = more heat.
With the split load disconnected engine power was returned to normal so Im gonna look at fitting a higher output alternator with a modern regulator. Trouble is this doesent explain Swampsters coil burning out as his split load relay was connected to his leisure battery but only the live was connected on the leisure battery so in effect the spilt load circuit was doing nothing.
Dave
DOH - haven't gotta clue wtf you're on about - but my curtains and cushions look really pretty [:X][:X]
)]:I
Moley and Brian the Snail
1965 Series IIA Bluebird Highwayman
Yea and everything Ive put could be total crap and it could just be down to duff coils
You want to sort that feed out to the coil like tim says they should be independent, sounds right dodgy we dont want Brian going up in flames.I bet the reg in the alternator is working overtime with the coil conected like that[:0]
The coil is fed just as Rootes intended, there is a seperate feed to the coil that is fused, this then goes via the ignition switch to the coil, the feed to the coil has to go through the ignition switch otherwise it would be permanently live and would burn out. Ive checked the wiring out and replaced loads of dodgy connections and taped joints, Ive installed extra fuses as one large fuse seemed to protect everything. I wouldnt want to suffer the wrath of Moley [xx(]if he did go up in smoke she loves that van
Dave
