hi, I have done a silly thing, while i had my manifold off to skim and re pain it got a gasket kit and decided to clean my zenith carb,
can you guess where this is going!! my service manual covers every carb known to man but the zenith, it all went back to gether fine and today i started the engine (eventually) the thing is behaving like it is flooding, it will run lumpy with the trottle half open revving, or with run fine for about 20seconds with the fuel pipe disconnected, so i have spent all day messing with the floats, but no change, does anyone know what the mesurement is for them? and where to mesure from? or if you know where the problem may be comming from? the valve seems ok but when the floats are ajusted stupidly low the engine cuts out but anything like normal hight and it is flooding. i am certain i havent left a jet out..
stripdown spec sheet anyone?
thanks
Ian
thanks
Ian
