shaune shaw
Hi All
im having issues at the moment with a Dodge autosleeper 1981
First issue was after i had fitted a new(brand new) fuel tank i ended up with a tank half full of water and half full of fuel,
next the fuel pump ceased and no fuel was being pumped through,
i then drained the fuel tank fitted an electric fuel pump (Facet posi-flow 12v)
inertia cut of switch and a Syntec fuel regulator 1 to 5 PSI
changed the spark plugs cleaned the carb and sat back.
Now the van starts but only if i cover the top of the carb and it sounds lumpy
i have had the regulator set a different pressures but it will only run when sat at 1 1/2 PSI
Help please running out of things to try
thanks
thanks
