Carb cables help
Hi Guys, Been off the commer scene due to finding and fitting another engine. Engine is in and was a donor from a later twin carb Hunter engine...the alloy head engine stylee.....
Problem I have at the moment is finding the correct cables for both the twin choke and twin carb. Do these run off a single cable with an additional linkage to work both carbs?? The engine did not come with any cables so as different from my old engine and quite a few of you have carried out the same change I am hoping someone can point me in the right direction!!!
Supercoolcommer now has the twin carb engine, an overdrive gearbox, and only failed its MOT on a small bit of welding on the floor and front brake cylinders!!!!.....Not bad for a 1968 Commer:D
Super Super Cool
There's a few clues on here
Commerjules will be able to tell you more.
http://66.129.69.181/forum/topic.asp?TOPIC_ID=1382&whichpage=2
Summer's here.....
So they say
I have the same engine with the alloy head and twin carbs, though am "upgrading" to SU carbs. The set up was two separate choke cables....only one worked though!!! This seemed to work fine. The two spindles were connected and there was one cable to one of these which actuated both, I will get a pic if I Can
