Bother!
Needed a piece of timber today, so popped down to Homebase in the Punto. Timber was 2.4m long, so I thought I would drive home with the roof down (it has a good heater). As to roof opened a crease appeared in the rear window, then bang, it split from top to bottom! [V] I suspect the plastic had hardened in the cold weather and become brittle. A repair has been made with strong waterproof tape.
I now need to see if I can get the window replaced, but it appears to be plastic welded to the hood rather than stitched. Otherwise, the roof is as good as new!
Ouch - try and find another[xx(]
Maybe you could cut the old plastic out leaving half an inch all round for some new stuff to be attached to. Not ideal but you could make a feature out of it using stainless nuts and bolts or maybe rivets:)
I sat in a puddle today my new 1999 Mazda (fiesta)sunroof leaks big time
from one leaky roof to another for me :I
& you thought you had problems!
hope you can get it fixed OK.
Amazing what you can do with some brass domed nuts or rivets as Panky says.
Maybe see if there is a glass alternative?
Unfortunately Baz, it has to fold in the middle. The repair I have made is sound and will keep the water out for the time being.
