hi there, we managed to do our first bit of camping this weekend and all went very well and very fun!! even got the van up to 70mph on the motorway down a long straight hill but it was a little unnerving so i quickly eased off!! she ran very well tho and we're really happy...
i was a little paranoid about how long the battery would last so i tried to minimize using the stereo and internal lights while we were parked up. the battery is pretty massive so i think it has quite a long life but i have been planning on getting a leisure battery.
it occured to me today tho that the stereo, heater and interior lights are all hooked up to the main starter battery at the moment, if i put in a leisure battery how would i switch all that over?
i understand about wiring the two batteries in parallel whilst driving to charge them with the alternator and then switching over from the starter battery to the leisure battery when you're camping but how do you go about supplying power to the components that are already connected to the starter battery.
even more concerning is that in order to use the stereo, i have to turn the ignition key, this brings the brake lights on because for some bizarre reason the handbrake triggers the brake lights! All this seems like potentially quite a big drain on the battery and could also presumably wear out the coil sitting with the ignition switched?!?
i'm not really sure how these things are best setup so any advice would be good.
thanks!
thanks!
