Back of the garage
;) got it, cheers for clearing that up, never seen this set up befor so loads to learn lol:D[^]
i went to beullie a couple of years ago and there was a Dutch (i Think) guy with a stall and he had some complete joints among other spares..I can't remember his name, he did use to come on here a long time ago...he had come over in a highwayman...I'm sure it had quite a unique suspension set up...ring any bells??
really can't remember....I think he used to boast of being able to supply brand new windscreens including ones with 'top tint' ...it's going to bug me now:I:)
Is that anywhere near Beaulieu Colin:D:D:D:D:D:D:Dquote:
Bloody Commer`s!
Originally posted by THE ICEMAN
A dutch man arrived in a Highwayman and had some joints? Nah it would never happen:D[}:)]
hahahaha I was thinking that as I wrote it :D[}:)]:D
It is now! Old age has caught me up....but I can still spell!:D:D
By the way, dont you ever sleep?quote:
and there was me thinking your brain was in fact the Watford GAP hahahaha:D:D
Bloody Commer`s!
Bloody Commer`s!
Not much Alan, far too much going on that won't let my mind rest, although I slept for 19hrs on Monday as I was unwell:I
Sorry Panky, bit of an unintentional hijack:I:I
New MOT nice:p. We had an advisory on the steering idler a couple of years ago. Speedies do the bushes and the pin and the job was no probelm expet for extracting the old pin. It took some blow torch action and a bearing press.;)
Thought I'd dust off this load of drivel and pen a few words of caution to those embarking om any clutch work.
It all started earlier in the year when I re-built Harvey's engine, while I was at it I decided to fit a new clutch plate as I'd not long bagged one off ebay. You may remember I had a bit of trouble with the clutch but eventually got it sorted even though it didn't seem quite right.
The gearbox was one I had to bits to adapt to take the overdrive and has always been a bit crunchy going into 3rd and 4th but on the trip to martins it got worse. A couple of weeks ago it became almost undrivable, coming home from Tatton Park show I had trouble getting any gears and I decided to swap the box. I had one I'd purchased for Bonnie but as it turned out it wasn't very good, that's when I sent out my plea for another, but when I was stripping everything off to take the box out I noticed there was very little travel in the slave cylinder - strange since I fitted new seals a couple of months ago. I took it apart and realised what I'd done, the seal kit consisted of a piston ready fitted with the seals so I cleaned everything up and plopped it in. The original cylinder was of a different type and there was domed a plastic guide that fitted to the return spring - stupid me left it in when the spring should have fitted to the end of the new piston, I'd lost nearly an inch of travel. So I put the old box back in thinking I'd solved the problem - no chance[V] Now I couldn't get any gears at all with the engine running, bugger I bet I've put the plate in the wrong way round I thought - so off came the box again. Nope, it was fine and I was very puzzled, I noticed the thrust bearing was a bit worn and was spinning in it's housing, so I reckoned it could have gone past the point of leverage so wasn't pushing against he cover plate enough to disengage the clutch. Mr M duly supplied one for me and the box went back on with the new bearing and a new cover plate, I didn't replace the pressure plate as that was new a couple of months previously. Bugger and bugger again still nothing, 'I wonder if the master cylinder is sticking' I thought as I lay on my back with the rain forming rivulets on my sloping drive and slowly soaking into my overalls. A few swift whacks with the handle of my ratchet on the master cylinder did nothing except to knock the rust out of a pinhole in the reservoir, as the Easibleed was still attached it looked like Harvey was having a pee. A few more buggers ensued and I decided to bite the bullet, new master and slave cylinders where ordered and again Mr M came up trumps.
So today they arived, all shiney and new, a matched pair so I knew they just had to work..............no chance[V][V][V][V][V][:(!] Getting a bit peeved by this time - but at least it's not raining:I The hydraulics were working perfectly, good travel at the gearbox end and as Barb pressed the pedal, peering in with a torch, I could see the movement being transfered to thecover plate. Surely I havent put the plate in the wrong way round, I'm sure I've missed a few box removals it seemed a lot more than I've described, so off it came again[:(!][:(!][:(!][:(!][:(!] and...............plate in the right way[V]
The only thing I hadn't changed was the pressure plate, so I thought sod it there's a bit of meat left on the old one - put it back in and see what happens. It was only when I had both of them together laying on top of the freezer that I noticed the difference[8)] The 'new' one was standing over a quarter of an inch higher than the old one. As it turned out the centre boss is a lot deeper on the flywheel side compared with the original one, all I can think is that the longer boss was touching the flywheel and forcing it against the cover plate even when the clutch was engaged, causing it to drag. I had to find out so the old plate went back in and I got everything re-built in just over an hour and that's with putting the oil in as well - I've had plenty of practice. And the result........ a perfectly working clutch at last:) A test run showed the crunching is still there in 3rd and top but nowhere near as bad as before - halleh flippin loooo yaaaaaaaaaaaaaaah.
The lesson here is if you but something off ebay 'just in case' make sure it's the right one before you fit it :I
How refreshing
Holy hell John...
I lost count of the 'ins and outs'. What a nightmare. Still no better man than you to find out the problem and fix it. I can relate just a little after ith trouble I had with icemans clutch.
I just need a good rootes...
I've always just fitted new master and slave cylinders (or professionally refurbed ones), never trusted just fitting new seals. Glad you got it sorted John.
Got lost about here..'pinhole in the reservoir' but i know that you are more than equal to the job unlike i;) Mister Pankhurst, if you need my help just say yeah...........HAHAHAHAHAHAHA
