Back of the garage
dare i ask if its the right way round:I
Must still be a hydraulic problem then:(
Might be worth checking for a leak on the pipework or cylinders, could be the master cylinder seals are shot and theres not enough pressure to disengage the clutch plate.
RH but we will see what it adds up to in july !
& hope I find a propper job soon [V]
The Colonel Mustard
Thanks Alan, I had the master to bits and it's pretty well perfect - tomorrows another day and I'll sort it:)
Two's company
and the very easy mistake of bolting the slave the correct side of the bell housing? .......sorry i know it sounds obvious but easily over looked:I
Thanks Colin, I have a few ideas - hopefully the last one wont be necessary, taking the gearbox off again:I
Two's company
Originally posted by Dodgemark
if not i will have to go and give a helping hand:I
Good grief, I'll make sure I sort it;)
Two's company
I had this the other week when I fitted the new master cylinder. Even when connected to a compressor, the ezi-bleed wouldn't the system sufficiently. Went back to the two man up.....down...hold technique. With some energetic pumping we got the clutch working.
Two's company
why would you need to take the box out again?? do you really think the plate might be back to front? ...:I
:I very funny panky:D i liked that one;) but what are you trying to say:I[?]
It's a long way from Bath to Widnes, by the time you got here I'd have fixed it:)
Two's company
gotta agree with Nick...I don't like those ezibleed things.....
coming from a man who can't even work a camera[:0][:0][}:)]:D
We likes energetic pumping:)
But there's no way I can get someone in the cab while Harv's in the garage:I. I can actually pump and bleed from underneath by myself - no comments please:I
Two's company
Two's company
ah for a minute there i thought you was trying to tell me i am useless:I:D
Two's company
It's one thing that's different, I'm 100% positive it's in the right way but what else can be wrong[?]
Two's company
