Patience my children - all good things come to those who wait
I've been a bit pre-occupied with enjoying myself camping remember, but..................
I bagged an electric fan off eBay, nice scoopy curved blades like the latest Kenlowe's and set about fitting it - dead easy:I
A sucker is more efficient than a blower so it had to go behind the rad.
I dug out my ancient arc welder and stuck a few pieces of 1" X 1/4" flat bar together.
For the fan to clear the water pump the rad needed to move forward a couple of inches so the position was altered using stud bar and lots of washers.
It's a tight fit, I thought I'd better try it with the pulley in position :I Must remember to put the fan belt on before I bolt everything up.
The Commer rocker cover won't fit the Rapier head and the oil filler cap on the Rapier cover is too long - it fouls the bulkhead - so a hybrid is the answer. I sacrificed the Commer cover for the good of the cause [8)]
Soldered a piece of metal over the old filler hole, just need to attach the filler in its new position.
Off out on a jolly tomorrow so will be having a break from Harvey:I
Th..th..that's all folks.
Well not quite...the finished article with spout welded up and tube for breather added..not forgetting the baffle on the inside to prevent oil pouring out of the vent. The colour isn't quite as disgusting as the pics suggest - it's the same as I used on the Mini head :I
