Back axle & front crossmember
both all complete and useable, 50 notes each :)
When you say crossmember do you mean everything from wheel stud to wheel stud:I
Bargain, just right for someone wanting to lower the front end. Measure and experiment in the workshop then swap them over[8D]
I'd be up for the front cross member! Are all the floppy bits servicable (ie not sloppy)?? The V6 is getting a front suspension overhaul for this year!
All seems to be servicable, however i would advise a strip/clean/check over ;)
That,s the crossmember, not the person :I:D
Hello Tim can i ask you to remove the gearbox mounted gear selector rod bracket please before it goes anywhere, i have asked Steve for the one from his highwayman but just incase anything goes wrong i have a back up plan, cheers mate.
The early bird catches the worm... but the early worm gets eaten first!
Hello Tim we recieved the bushes on friday thanks everso for the promptness with those, if Sam doesnt remind me, give me a gentle nudge at the next meet and i will cross your palms with silver, im bound to forget between now and then. its going to be good to get them in and run the van again. thanks also for the research into my non existant gearbox mounting bracket:I;)
I'd rather have a bottle in front of me than a frontal labottomy!
No worries Nathan :) we were a bit concerned about it getting to you, being such a small package :I good luck with fitting them ;)
Its all sorted John, he was looking for a bracket that isn,t supposed to be there :D
