Auto shifter
admin
I got to think my cab could be a lot more tidy/flush if I had an original Commer auto shifter
Having tried the usual suspects direct without joy I am hoping that someone has stashed away or removed from other vans a spare automatic shifter for a Commer (the bit that goes in the dash rather than a whole gearbox etc)
Let me know if you can part with it
Someone was about to convert from auto to manual recently - you could be in luck:)
Summer's Coming.....
Trust me
http://66.129.69.181/forum/topic.asp?TOPIC_ID=5448
Here it is
If you havnt already sorted, if any help ford transit mk 1 auto lever is very much the same , dash mounted and bolts straight in the dodge spacevan dash type at least , all that was required was an extension of the cable end ,
s.arnatt
Hi steve rejhall knows that I want his when he carries out the conversion but I will also keep an eye out for mk 1 transit levers
