Antifreeze
commerchris
0
Anti freeze I have just in time added
undilutded to my system.Iirc the system holds
7 litres? I un-done the top of the bottom radiator
hose to drain some water away.Put hose back on
& added 3 LITRES WHICH FILLED IT BACK. UP DOES THAT SOUND OK?
just hope I did the hose up nice n tight
:I
7litres? thats something else on my list i can tick off :)
can i take the bottom hose off and start the engine from cold for about 30 seconds to flush the old stuff away ?? And then refil?
and also i had loads of steam coming out of my thermostat housing do you know where i can get one Tim ?
Probably be best to drain off what you can out of the bottom hose, refill and run the engine then drop the water again a couple of times, wouldn't do any harm to use a flushing agent while your at it seeing as the engine has been stood for so long. Once that's done tighten everything up, put your antifreeze in and top up with water.
Is it the domed end of the housing or the larger bit behind it attached to the head that's leaking?
30% antifreeze is usually enough, a bit more wont do any harm. But don't get the yellow stuff designed for modern engines, make sure you get the one for older engines, it's usually blue.
Oh okay thats good then :) i nearly bought the yellow one in Tesco today! I will get some thanks :) the dome bit on the edge where the hose attaches too? Its cracked at the domes edge it was like a kettle boiling!
Thanks
Common fault, due to over tightening and an uneven gasket face[xx(] Hopefully one will come up, they're not cheap new:I
Perhaps it could be weld repaired?
Mr racer?
When you get the antifreeze read the label, it should say something along the lines of - 'suitable for older engines built before.......'
Speedies sell the caps and housings
http://www.speedyspares.co.uk/cgi-bin/speedyspublic/speedysweb.cgi
Click on the Commer PB link and scroll down to Cooling System. Hopefully its not the main housing that's gone:I
I think its worth hanging out for a second hand one or, as Chris says, maybe a repair.
Isn't "Anti-freeze" an amazing product. We have you guys up there adding it to prevent freezing and us lot down here adding the same product to raise the boiling point of the coolant to prevent boiling. Can't think of any other products that improve both ends of the spectrum and also assists in corrosion protection as a bonus.
Strange colours you mention, ours is green for older motors and red for the newer. Check the label on the container or the company website for best concentrations to run. I use an Australian made Nulon Long Life Coolant, which advises the temperature changes at different concentrations on the container. I just checked the label which is as follows
Standard Conditions Using Coolant + Demineralised Water (33%) Boiling point 127 deg C Freezing point -18 deg C
Extreme Conditions Using Coolant + Demineralised Water (50%) Boiling point 132 deg C Freezing point -37 deg C
I remember seeing a data sheet many years ago showing higher concentrations of coolant (might have been 67%) with the boil point going up to to 141 deg C, but the Freezing point was worse than 33% & 50% concentrations. I ran that higher level in my rally car. Freezing wasn't something we ever had to worry about and you could drive as hard as possible in the heat of summer with the Temperature gauge occasionally well into the red and not have to worry.
Also worth considering if you haven't already got one is an expansion tank/bottle as this will keep the radiator full as the expanded coolant is captured in the bottle as the motor heats up and draws it back into the radiator as it cools. If you do add the expansion bottle remember to get a replacement radiator cap intended for use with an expansion bottle.
Cheers Stephen
I've always used 50/50 mix all year round - works for me.
Send it over for weld repair Luke ;)
Ethylene glycol is what you want as anti freeze. And no more than 50% :)
I keep the housings and caps in stock, New and used.
