Zenith Carb 4 Service Sheet
Many thanks to Steve Williams for this service sheet and my carb it has saved me a lot of problems.
So that other people can find help with this carb the service sheet that Steve gave me is here.
http://www.commer.fizwig.com/
it is really hard to find good info on this carb so this should help any one who is looking for info,
good luck
Ian
Ian / Steve would it be ok to put a copy of this in the mechanical section of Commervanfan?
I am trying to get the full workshop manual scanned and in PDF format for people to make use of, so it will make a welcome addition to the "documentation" section
Hi all,
Is this carb also use for the walk thru models? (6 cilinder)
Thx.
Check www.commerwel.nl
its fine with me to copy and keep,let me know if theres anything else you may need
dont think its the same carb as for your 6 cylinder walkthro,best person to ask is joan or sarah at speedy spares,they will tell you
Building on Steve Williams good work, I have assembled all of his 8 pages into a single PDF document and added a list of contents / bookmarks which link direct to each topic. Intended for my own use but if anybody wants me to send them a copy just drop me an email.
