you dont get that with a commer!
Just got the jag back from the diagnostic man - was a flash memory fault, narrowed it down to when i walloped a pothole recently - reckons it happens all the time on modern cars, all reset, all now fine but cost bloody fifty quid - - - - -- glad it wasnt an expensive oxygen sensor or similar though ( he also reset the date the transmission fluid was changed as he reckoned that would be coming up soon )
The Dog is on its way....
....... that didnt last long, light back on - bloke wants another 50 quid to reset it - he can poke it, it drives fine
Heater Matrix needed for the Audi - needs the autoelectrician to remove the dash so bang goes £500!
or go cold ? :I
just sorted new windscreen for the pug being done on Monday few bits & bobs to do still not too modern though :D
Sybhil
I'm all for skimping on non-essentials Chris but when there's steam coming out of the vents (in a major way) which means it losing water and temperature at over 110 degrees on the way to the garage I just had to bite the bullet.
Originally posted by Navyreg1970
A little man with a laptop is going to tell me how expensive this is going to be on friday
Im one of those little men with a laptop;)
There an easy way top earn £50 thats all i can say!
You should have brought one of these.
http://cgi.ebay.co.uk/CAR-DIAGNOSTIC-SCANNER-CODE-FAULT-READER-MAXISCAN-MS509_W0QQitemZ110514578960QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item19bb2ea610
There quite easy to use and you can clear the faults.But of coarse you need to fix the fault first not just clear it like you man has done.It might be the fact hes software is not doin the buissines with your car,as there are two ways to access the information on the ecu. You can enter it through eobd or manufactures data which is more accurate. The cheap code reader on ebay will only be any good under eobd codes (P codes) which are very basic.It does say on listing it will work with manufactures but have never used this system so might be ok. I have an omnitec system which also does many abs and air bag faults but there about 2grand so not for your average diy mechanic;)
have one of those in work, but the socket on the jag has two tabs which prevents it from fitting
What year jag is it? If its after 2001 should be EOBD so will def fit.
strange how i couldnt get mine to fit.... obviously not shoving hard enough, will have ot rob it from the guy in work again
Make sure you got the plug the right way round as it angles in on each side and will only plug in one way round:I;)
