andrew 0 Nov 22, 2015 #1 im going to put a temperature gauge on my van, it's a smiths gauge. Does anyone know the correct wiring for it.
Panky admin 2.0 Staff member Nov 22, 2015 #2 It's possible that the wiring is already there wrapped up in the loom, but it's simple enough to do. You will need to run a wire from the voltage regulator to the gauge then from the other side of the gauge to the sender unit on the engine.
B bazzateer 0 Nov 22, 2015 #3 Make sure you have the correct sender for the gauge, if they're mis-matched you'll get inaccurate readings.
