auto-electrics!?!?
I followed BMM advice and bought a new 7 pin plug connector and have wired it up. I also noticed my van had been wired up for a tow bar before so used the previous connections. Thought it was going really well, even when i started the acid test... the tail, n/plate lights work and the L&R indicators flash when the lever is dipped or raised. The only problem i have is that when the brake pedal is pressed BOTH INDICATOR LAMPS come on onstead of the brake lights! - PLEASE CAN ANYONE HELP!
Cheers, Ray
Cheers, Ray
