White/Cream Colour Code - 1970 Autosleeper
JJ Autosleeper
Does anyone know the colour code/spec for the base colour for a 1970 PB.
I attach a photo of the under dash areas which I assume is early paint. It is an off white. Would that be Arctic White? 407705C3-3040-4420-95EF-F2C2223F45B7.jpeg
The outside is now cirrus blue and cream with cream wheels, but I assume would have been all white as a standard offer from Autosleeper.
If anyone can help please post. I can’t see anything on the forum on this.
Thanks.
Jonathan.
I’m not sure. Autosleeper did do 2 colour not sure if they did a single colour option. I did contact Autosleeper to get archive pics etc but they had a fire back along and lost archives. If there are lots of layers of paint they may go back to original. Hopefully someone on here will be more helpful lol
Your pick is typical of just about every van I've seen, they come like that out of the factory before being delivered to the converters. Try lifting one of the door seals and you might find the original colour under there.
Hi.
I’m just looking to match the interior colour to repaint the front floor to match the base colour which is the off-white. And reoccurs on the inside surface of the wheel arches. I’ll probably stick with exterior colour scheme.
if anyone knows the colour code for the off-white let me know. Thanks.
Mine is a bit later than yours but it may have been the same colour. Ermine white. It says Dodge but you never know..
