hi poppi,measure the space available,should be 12v,check the terminals that connect,see if they are round or square,mine are round.that should help,good luck,,,don't forget pic's
Tell the battery centre what vehicle it is, you never know they might actually have it listed. Failing that tell them the engine size and make sure the terminals match up to the wiring in the battery box as they can be supplied with positive on left or right depending on vehicle. Also get a good heavy duty one
Thanks all will probably have loads of other silly questions for you.Have to check out fabrics too thought lime and turquoise would be "cheerful" and I think we're naming her Elsie.For pics do I just copy/paste on this site?
You need to set up a Photobucket account or similar (dead easy) and then follow admins instructions in 'Posting Pictures'. If you are having problems you can email pics to one of us and we will put them on for you.
