Needing help - Threads on manifold studs were worn and wouldn,t allow manifold to nip up tight enough to seal manifold to head. Just replace manifold studs on head after two breaking two trying to get them out so head came off. In process notice face of manifold badly worn /pitted and slightly different level between inlet and outlet faces so had face skimmed so that all all faces were smooth and on same level. All refitted but now van won,t start at all and backfiring. Two questions;1st one really stupid. When replacing head put new head gasket on but stupidy put it on wrong way round with hole or water chanel at front than where it should have been at back. I assume I need to refit new head gasket again ? 2nd One - Im assuming that slightly different level on inlet /outlet faces shoudnt have been there and skiming flat was the right thing to do? Having taken it all apart again it seems to look like along the bottom edge of the two center ports that the manifold gasket wasn,t as tight against both faces as elsewhere( the texture imprint of the gasket isn't evident there) Could this be my problem where air is getting drawn in and I'm being too nervous about tightening them up properly( and breaking new studs in head again !) , although I thought they were nipped up pretty tightly ?
Any help appreciated
