You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
was fitting the new points to Patty and found no pipe to the vacume unit on the distributor
where should the pipe be connected to at the other end[?]
Here you go, the black pipe attached near the base of the carb.
[/IMG]
[/IMG]
Cheers thats tomorrows job if the snow stays off
