The fun has begun , bell housing slave cylinder leaking
Tintop
Hi all , Mertle the Turtles commercial 1961 slave cylinder is leaking , my question is , what parts I need to solve the problem , are they interchangeable with other makes and models , would I be better off just buying the whole parts rather than a repair kit . Any help really appreciated
Hi - seal kits are available and simple to do but for the cost and simplicity I’d put a new one on in case it’s worn or rusty inside but guess you could check that - Martin Malta’s has new in stock I believe
Thanks jimberlake, really appreciate ur help, I will check out Martin to see if he has any , I may aswell grab some seals for the other master cylinders , Thanks again
Hi again has Martin got a page with parts on it ? Or how can I see what parts he has
I looked at a repair kit and it was almost as expensive as a complete cylinder. When I removed the old one it had failed because the bore had a rusty groove along the bottom.
