That rubber grill seal thingy
Im looking for the seal that goes round the square hole that sits behind the grill..y'know?
The one on Percy looks pretty manky so need a new one
Percy-1975 Highwayman
I had the same problem and have found some on e-bay which fits around both skins perfectly, [although a very slightly different design]. It is item number 190303247403,rubber car door boot black seal edge trim [phew!] from autoparts direct. It is £3.40 a metre. Dont assume as I did a metre is enough, I have had to re order 2 metres as it was about 4 inches short:I hope this helps.
Hi Martin, should have realised you would have it, do you have the correct trim fittings for the front grille?
Originally posted by martin maltas
I can do the correct one ;)
How much for enough to do Percy?
£5.00 plus post ;)
Have you sent that exhaust sealing ring?
Because if you havent then maybe I could get the money sent over asap to save on postage plus im still interested in the front valance so maybe I could get the lot sent together?
