Tank Sender
We have soldered the coiled wire inside this some three times now, over the years:)
So when the fuel gauge stayed on empty again, I thought I knew the problem... however:
Tha camera just picks up a fluid line[:0][xx(]
Now that's never happened to us before[V]
If you can,t get an original float, then improvise one from another cheap sender off Epay ;)
Hmm...this Mini one might fit:)
http://www.ebay.co.uk/itm/MINI-PETROL-TANK-FLOAT-/290373106195?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439b95fa13
Looks close enough, another Commer/Mini cross-over[8D]
Happy Days.......
Looks like it's holed (red arrow) at the end of the wire[xx(]
A self tapper might seal it till the Mini one arrives:)
Will petrol not dissolve the filler? If you want to bodge it, couldn't you melt some plastic into the crack?
Dunno, soon find out though:D
How would you suggest I do that then, Colin[?]
Originally posted by Dodgemark
Dont think I would use filler in contact with petrol:(
Nor me:), thats why I've ordered a Mini one;)
Looks like it might have been alright 2 years ago but now there's alcohol mixed in[:0]:(
There's even an e-petition on the subject
http://epetitions.direct.gov.uk/petitions/15535
have you got a soldering iron? (obviously yes because you said about soldering before) Why don't you just run the soldering iron over the crack and let the heat seal it??
Interesting Colin, so have you done this before on a petrol tank component that has had petrol inside it[?]
LOL...no! but can't see a problem as long as its dried out, I mean people weld up leaky petrol tanks once drained and dry;)
Sure is a relief having a working fuel gauge again, polyester resin repair and all:D
There is merit, however, in a plastic weld solution, which I may try, then keep as a spare after the new one is fitted:)
Just a minute though...[8D]
Arrived this morning, but too much petrol now in the tank, and we have to wait untill the level is back below the sender opening before sender removal again:)
Well the polyester repair didn't disappear in the short term and didn't even leak:I
But this new float fits beautifully with no adjustment needed[^]
Better design, also lighter:p so should float even better:D
