Switches
Anyone know where I can get large commer sized panel switches? The only ones I can find are too small for the apertures.
They are very difficult to get hold of I'm afraid. I seem to remember someone swapping the internals over from the smaller ones into the larger ones. Alternatively is there enough room to make an adaptor plate for the small switches to go into the bigger hole?
Yes, I think the adaptor idea is the best way to go. This is the sort of occasion I wish I had a 3D printer!
Found on eBay. You probably don’t want a fan switch but part number may help if similar numbers for large switches??C338720C-B7A2-44BD-A825-720F22DB41E3.png
That's the right size but I need a hazard warning switch with six pins on the back. I've found the right size but it has spade terminals so I'll probably get that and change the harness fittings.
