JJ Autosleeper
I have a problem with my near side front tyre touching the l/h inner cill when reversing when the van is loaded. When jacked up and freely rotating it’s got lots of clearance. The off side does not hit the r/h cill when reversing the other way.
I checked the l/h r/h steering wheel turn to full lock both ways. To the left it’s 1 and 3/4 turns. To the right it’s 1 and 5/8. So I am getting an 1/8th more turn to the left than the right. Which may explain the tyre hitting the cill.
Can the stopping point be adjusted or does the steering gear need centralising? I can see you can adjust the left/right readjusting the rear track rods equally left and right - but it can you do it via the front connecting arm?
Any advice appreciated. Thanks.
