Starter Motor issue!
Hi peeps.
Been out on the van today and attempted to start it for the first time in over a year and a half and she wont start:(
I turn the ignition and it just goes weeeeeeeeeeeeeee? The starter motor doesn't kick in and try to start it for some reason? Is it seized?
Could a whack not sort it? I haven't got any petrol running through at the moment but i guess that doesn't really matter yet as i need the engine to turn in order for the pump to work!
Any ideas. Do these things just pack up working if left standing for a time?
Cheers;)
Could be pinnion stuck and not throwing out. Could also be lack of current, check battery level and earths ;)
Sounds like the pinion is stuck Scott, easily sorted :)
Pull the starter off, it,s the gear on the end of the shaft that is supposed to slide up and down, you will see it ;)
But mine isn't one of these types???
http://www.ebay.co.uk/itm/TRIUMPH-SPITFIRE-RELIANT-MG-MIDGET-STARTER-MOTOR-101-/300747576265?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4605f3d3c9
