Speedy Spare Full Engine gasket set
Hiya. Can anyone tell me what the above set actually consists of?
Speedy's are closed until Thursdqay and I am trying to work out what I need to order. I need timing chain covers, water pump, rocker cover gaskets, and maybe a few more for good luck!
Thanks
I think but not sure head gasket water pump gasket rocker cover gasket etc sump gasket it should be every thing you need to rebuild an engine,we do have some but most have been opened so probably not very accurate contents.
Sybhil RIP No.1
I've just had a look in my new head gasket set, it contains everything for the top end including thermostat and side cover gaskets. No water pump gasket in there.
Dohhh - I know that but Charlie had had most of the top end in bits so a HG set and a water pump gasket should do the job - and he'll have a head gasket in stock then should he need it:)
Chris, Hopefully I will have a second engine after visiting Kes at the weekend. Then one will be in Frodo, and one will be (temporarily) in pieces, all parts will be used at some point I'm sure, and if not, I'll have a spare head gasket, for when Panky blows his ;)
