Checked over ours last night, seems a good 'un with only minimal corrosion pitting on edges of waterways, no cracks evident from a visual inspection plus and decent looking head face, might clean up OK and not require a skim.
However I did discover 2 minor issues ;
a) Small washer lodged in a waterway and mildy corroded in place [:0] Wouldn't have done the waterpump much good if it'd worked loose ! Quickly resolved and now removed.
b) Partially stripped threads on 2 of the tappet cover bolt holes - not sure what best to do here. Basically understand the concepts of re-tapping and/or helicoils but never done either, so gratefully appreciate any recommendations on what best to do here.
(Will post pics later)
We might not need this head if the one already on our Holbay engine is fine but our ex-Rootes mechanic has told us to expect the worst, as he's seen some shockers in his time !
Thanks
Commer 'Hi Tor' by TorCars
Thanks
