hi you lot out there, i thought i might share this bit of useful info with you all tonight, i found out today from a very good friend whos into commers and old classic cars that if your door mirrors are knacker on your van you can pick them up quite easily and cheap,because they wernt just used on commer pbs they are exactly the same mirrors as used on the series two and three landrovers, ive had a look on ebay to confirm this and they do look more or less exactly the same. this friend also showed me some rubber mountings and bump stops that are on the commer which are also used on the same land rover. so keep your eyes open if you need any. good luck.
