Hi Guys,
Just a quick one on the resto of Miss Piggy
I've removed engine and gearbox
the previous engine fitted was a holden 6cyl and they lengthened the
rear of the fire wall and extened the lid to suit and did a really bad job of it .
Then someone fitted a Nissan L20B 2lt motor with a 3 speed auto
But it was mounted to far back so i decided to move it 6 inches foward and weld up a new rear fire wall as the old one was just held together with bitumen tape.
So was to fit a Mitsubishi L300 auto shifter and cable on the front firewall panel for easyer access as old T bar shifter was fitted way down low on the floor where the old manual shifter originaly was.
Now thats done i'm thinking changing over the running gear to something more modern, maybe holden commodore rear end and front disc setup? as the nissan motor should push her along quite well.
Well till next update all you can do is have FUN.
Frank Healey
Frank Healey
