Rapier OD Box ???
admin 2.0
This doesn't look like mine:I
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320560938453&ssPageName=STRK:MEWAX:IT
Harvey the RV
Think there was someone on here just recently looking for an OD? This looks like mine so should do fine.:)
A commer down under - or down under a commer?
This box is identical to the one that I recently fitted to Bumble. Be aware that you will need to cut your existing mounting to make it fit. Also, note that this box has ten splines rather than the usual Commer multi splined end. Not only will you need to get your prop shortened but you may need to source a new prop end as well.
If you need any advice on fitting, I will be happy to help.
Jim, Nols and
Bumble
Ah it's the earlier Rootes type:I, the gearbox itself threw me as it's different to the usual Commer one.
Harvey the RV
