Has anyone fitted a non standard Rad ? If so what one? Also what would you use to clean out a Rad that’s off vehicle? And I’m after a very small toilet area window maybe tiny Louver?can’t up load photos says to big Thanks
Scary stuff! The Dishwasher Tablet is in and Engine running for 30 mins Will keep you postedI renewed the core plugs, as some were leaking, but the gearbox and flywheel had to be removed to get to the rear one. The amount of crap that was behind them in the block was scary, a jet washer and poking wires through the openings got rid of most of it (very messy) but failing that several chemical flushes won't do any harm. Probably best to dump the chemical while the engine is warm, and the sludge is still in suspension, by pulling off the bottom hose.
