Tintop Active Member Oct 24, 2022 #1 if I remove the hoses from the heater ,should I expect water to come out of the heater itself even after draining from the bottom hose of the radiator ?
Panky admin 2.0 Staff member Oct 24, 2022 #2 You may get a dribble but if the heater tap is open most of it should drain down once when you pull the bottom hose off.
