Can anyone help please, coming back from Southwold at the weekend the overdrive started to 'slip' on the Autohome. I read through all the advice and first checked the oil level in the large 1" bolt on the gearbox, I believe this also feeds the overdrive? I could feel oil (which was very clean by the way) so I assumed that the oil was OK, a good thing as I was a little confused which oil to use anyway, 20/50 or EP80 or 90, monograde, no additives????
So I put the van into 3rd gear and flicked the overdrive switch. There was an electrical clicking sound, like the sound of something shorting......... not what I was expecting to hear, which was I suppose something engaging?? I looked at where the sound was coming from and it was the unit where the single electrical wire is attached, I assume this is a solenoid? As this part has a relatively transparent top cap, I could see electrical sparking, like something was arcing inside. Is this what should be happening or have I found the problem?? if so could anyone advise me how to fix it[?]
